which setup would you choose?
12" rotor and 6 piston caliper or 13" rotor and 4 piston caliper??? just doing a little brake shopping and wanted to pick the mind of you brake guru's!!! any advice and reasoning would be greatly appreciated! thank you
yup, bigger rotors have more surface area which gives you a little bit more cooling vs smaller ones. 4 and 6 piston calipers all vary from power from such things as like different size brake pistons, brake pads and possibly vehicle weight. example, a 4 piston may have 4 bigger pistons and is equal to the power of 6 piston with 6 smaller pistons. also consider you may need a bigger brake booster if the calipers are too big to supply enough fluid to the brakes.
Originally Posted by 08s2000CRbackinblack,Dec 20 2010, 01:07 PM
im looking at wilwood superlite 4 piston calipers. would that need a bigger brake booster?
Originally Posted by Oakes,Dec 20 2010, 07:18 PM
have you looked into OEM BBK kits? for example TL-S or RL? currently i got RL 4 pot for my accord instead of regular 2 piston brakes from legend GS.
with custom brakets it can be made to fit S2k im sure
its hard to beat a bbk price of $870 with those cailbers, on 13" rotors, and lines. the reason the kit is cheao is because they arent two piece racing rotors, just vented 13" rotors similar to oem style but huge and this like the amg kits or whatever. sounds like a nice bang for the buck hit
