Steering Not Returing to Center
Hi everyone. I have a MY07, and had a steering question. First off, the car drives straight if my hands are off the wheel, no pulling at all. The steering wheel is a bit off center when the wheels are perfectly straight, but I not sure if that's related.
My issue is that if I'm turning, the car will not straighten itself out if I let go of the wheel. Basically, if I turn the steering wheel for a turn, the car will continue turning and the steering wheel will stay at that angle even if I let go of the steering wheel. I thought it might be due to the EPS, but I wanted to make sure there was nothing wrong with the car. I figured I'd get an alignment and see if that helps?
Thanks,
Ken
Thanks,
Ken
It sounds like it's just a simple alignment issue with way too little caster (shoot for 6-8* of caster). The steering wheel being off center is almost certainly an alignment issue as well with the tie rod being too far out on one side.
-Matt M.
-Matt M.
I have also recently seen a worn set of tires do some funky stuff to the steering wheel being off center when going straight. If the alignment is perfect and you still have the issue, tires are the next thing to consider swapping out as an experiment.
Awssome, thanks for the help everybody! Fortunately I live about 20min away from Science of Speed, so I'll have them do an alignment for me. The tires are brand new, so I don't think it's due to them.
In case anyone was curious, ended up being waayyyyy out of factory alignment. The alignment guy at the Honda dealership (who apparently has four S2000s) said it was like someone had tried to give it a track setup and went way overboard.
I think I have 7 or 8 deg.
I have -1,5 caster ans 0 toe.
Wheels doesnt center all the way either. Feels numb.
dammitjim
Jan 1, 2024 06:49 AM
