Sponsored by: Sake Bomb
sway bar
Old Jan 11, 2012 | 10:47 AM
erikvanden's Avatar
Default sway bar
I was wondering if I should purchase front and rear sway bars. I have an 01 and from my understanding they are already stiff. I do autox though and I know a lot of people with S2Ks have recommended sway bars. any thoughts on them?
Old Jan 11, 2012 | 11:24 AM
User 121020's Avatar
For auto-x, people typically get a stiff front anti-roll bar and find a softer rear anti-roll bar. Many of the STR participants use the '06+ NC Miata front anti-roll bar in the rear of the S2000 or no rear anti-roll bar at all. What auto-x class are you building to?
Choosing an anti-roll bar setup needs to be properly selected based on spring rates and tire sizes. Any other modifications to your suspension system?
What about your current setup do you dislike? What characteristic is pushing you towards anti-roll bar changes?
Old Jan 11, 2012 | 12:13 PM
erikvanden's Avatar
I have stock suspension with 17in wheels. 225 front 255 rear. I really just wanted to decrease roll and get better times. I just know a lot of people who have got new sway bars have said it helped a lot. They have newer S2Ks though.
Old Jan 11, 2012 | 03:54 PM
TTMartin's Avatar
A stiffer front sway bar should reduce body roll.
Running a staggered set-up there is no reason to disconnect or go to a softer rear sway bar.
Old Jan 11, 2012 | 08:33 PM
Croc's Avatar
i'm happy with Eibach sways.
Old Jan 11, 2012 | 09:07 PM
Carbon Blue's Avatar
Im in the same position as you except ive got bilstein pss's and stock sized ap1 wheels. I want a stiffer front sway but dont want more induced understeer.hmmmm
Old Jan 11, 2012 | 10:13 PM
Back S2k's Avatar
i think this is impossible to achieve if the only variable u r changing in ur set up is a stiffer front bar.
Old Jan 12, 2012 | 08:55 AM
Alignment can be used to negate understeer when adding front roll stiffness. Less rear camber, more front camber, less rear-toe in...these will all promote less understeer.
Old Jan 12, 2012 | 03:01 PM
For an AP2, agreed. For an AP1, I think the added front roll stiffness is beneficial.
Old Jan 13, 2012 | 06:13 PM
erikvanden's Avatar
ok well what sway bar would be the best bang for the buck? Do I need to spend lots of money? or will an ebay bar be good enough?
