Sponsored by: Sake Bomb
sway bars
Old Mar 20, 2013 | 09:09 PM
Knoweyedea's Avatar
Default sway bars
Im planning on getting sway bars for my 01 ap1 and these are my options
front eibach with stock rear or cr rear
front cr with stock rear
any suggestions or better options would be awesome. thanks guys
Old Mar 20, 2013 | 10:22 PM
MBHs2k's Avatar
The 00-01 S2000s have the same size front sway bar as the CR. Get the Eibachs. Good quality at a good price
Old Mar 21, 2013 | 09:15 PM
habbibaS2K's Avatar
how are godspeed sway bars front and back?
Old Mar 22, 2013 | 09:15 AM
devildust's Avatar
I have an 01 as well and we have a pretty stiff front already, as well as rear, too stiff a rear. So I think our cars would benefit more from a softer rear sway since stock its stiffer than front.
Old Mar 23, 2013 | 08:43 PM
Knoweyedea's Avatar
so which sway bar would i change? the front or rear?
Old Mar 24, 2013 | 08:15 AM
Breaking Point's Avatar
I got an 00 with a whiteline front and 07ap2 rear
Old Mar 24, 2013 | 02:53 PM
Stock00S2K's Avatar
agreed. I have an 01 with stock front and Ap2 rear. Perfect.
Old Mar 25, 2013 | 05:08 AM
Yea it made the car very neutral feeling. I put the big whiteline front on since I'm running a square setup and it made it feel much etter. I picked the 07 being the 06-07 had the 130series(smallest/weakest spring rate) to fit my needs.the little miata bar was to little spring rate for me and the No rear bar I didn't enjoy.I also added energy suspension bushings to the rear sway bar like I did when I had my OEM bar and the car is awesome. Next is adjustable endlinks and some more bracing.
Old Mar 25, 2013 | 06:26 AM
SlowTeg's Avatar
Are you staggered or non-staggered? I think it's important to specify in your post since that makes a huge difference for the setup.
Old Mar 25, 2013 | 07:59 AM
I run mine staggered thru the winter and fall mountain trips and car feels nearly the same.oem rim with oem sizes
