Swift spec R springs
I just installed some swift spec R spring on oem shocks for my MY03 S2k, intial inpressions are, are these softer than my stockers? They feel just a tad softer over bumps, I really dont feel much of a difference in turns as in weight transfer. They are supposedly 7.4kg frost and 7.0kg rear, significantly firmer than the stockers but why do they not feel that way? Anyone else have experiece with these springs? The drop is modest and decent looking, im ok with that. Also why are the coils so close on the bottom side of the spring?. I looked underneath the car and the bottom springs are touching each other. Anyone have any insight on this?
This a common concern, and a valid one too. I have had a lot of experience with there springs... a softer more compliant ride is definately a good thing though, and the reason why swift springs feel soft is because the material they use to manufacture the spring 'H5S.TW'. This material is stronger than regular silicone chrome material and therefore allows less coils on the spring; while maintaining a strict linear spring rate. So the spring in turn may feel soft but in technical terms it is actually promoting travel of the strut without binding of the coil. If the spring was too stiff it would feel uber bouncy and would crash over bumps, unlike the swift springs which will adhere/contour the surface. Believe it or not, there is a crap load of engineering that has gone into those springs which is why they cost almost twice as much as other lowering springs.
If I'm not making any sense or if you seek a more detailed response give swift a call. I personally know the Sales Manager and he would love to hear your concerns/feedback.
Lenny@Swift Springs
1.909.923.9788
There is also additional information on their website...
www.swiftsprings.com
-Jacy
Lenny@Swift Springs
1.909.923.9788
-Jacy
i have those springs on stock shocks (MY05) too.... they do feel similar to stock in terms of ride quality, but the springs are definitely stiffer than stock as i noticed the car actually have significantly less dive under hard braking.
Lenny@Swift Springs
1.909.923.9788
-Jacy
Lenny@Swift Springs
1.909.923.9788
-Jacy
Lenny@Swift Springs
1.909.923.9788
-Jacy
Lenny@Swift Springs
1.909.923.9788
-Jacy
EvasiveMotorsports
Jan 24, 2011 02:06 PM
sss2k921
Jan 4, 2005 02:03 PM
