Tein circuit master type rs
The Type RS damper has the advantage over TEIN's RA and RE coilover system with its damping force adjustment feature. With separate compression and rebound adjustment (16 levels X 16 levels), this allows the driver to setup the suspension damping force to meet any track conditions.
Exclusive Designed Pillow Ball Upper Mounts for Optimized Performance
MonoTube Design for Maximum Performance
Full-Length Adjustment & Height Adjustment for Separate Setting of the Height and Spring Preload
16-Levels of Damping Force Adjustment (Compression & Rebound Together)
Extra Reserve Oil Tank for Larger Oil Capacity for Wishbone & Multi-Link Suspension
Inverted Shock Structure for More Horizontal Stability
Available for Overhaul
Found this off of a website
It's probably an older design as it is similar to the features of the SRC. It was probably supplanted by the SRC
I have been using these since 2008. I absolutely love them. I did step up to 12K up front though. They are an older coil over (Ap1) but i have zero complaints. Great on the street and track.
161MPHTOPSPDS2K
37
Feb 18, 2009 06:52 PM
600rr_rocket
Sep 4, 2008 08:17 AM
