Sponsored by: Sake Bomb
Using Ap1 Spindle/Knuckle on Ap2
Old Mar 29, 2016 | 07:49 AM
Orjinal's Avatar
Default Using Ap1 Spindle/Knuckle on Ap2
Hello guys. I'm in the middle of swapping an ap2 subframe/upper control arms to my ap1 and have a question about the rear knuckles. Per their respective part numbers, ap1 and ap2 have different rear knuckles. But my question is are they interchangeable? Has anyone looked at them side by side? Are there any(if any) differences between the two? Thanks in advance.
Old Mar 29, 2016 | 11:54 AM
gptoyz's Avatar
it's different geometry
go get the ap2 components for your swap
Old Mar 29, 2016 | 01:08 PM
Orjinal's Avatar
I know there is a difference between the suspension geometry of both and my question is would using the ap1 knuckle have any negative effect on the handling of the car?
Have you seen both knuckles off the car, next to each other?
Old Mar 29, 2016 | 04:19 PM
gptoyz's Avatar
no I haven't but Honda isn't the kind of company to make 2 different part numbers without a significant difference
Here's what I a search revealed:
http://honda-tech.com/honda-s2000-5/...rison-2173176/
"One owner’s research found the front suspension received a new front upper arm (left side only); some owner’s speculate that was to correct difficulties in setting the camber on that side. There’s a new part number for the self lock cam nut and bolt at the lower arm’s adjustment point. There’s a new part number for the front lower arm but no apparent geometry change; it’s thought to be a test spec. There are no apparent changes to the front sub frame. The rear suspension received a new knuckle and they moved the mounting point for the control arm. The bushing for the upper arm now has a separate part number; previously it bundled with the part. The tabs for the rear upper arm in rear sub frame have a new part number; it could be durability or geometry change. Front and rear hubs remain the same. "
my advice; if you want the benefit of the ap2 suspension; then do the full swap with the ap2 knuckles
Old Mar 29, 2016 | 04:48 PM
Orjinal's Avatar
Ok, thank you.
//steve\\
Apr 16, 2015 05:41 AM
marky128
Dec 2, 2014 12:20 PM
Bullwings
Oct 14, 2010 11:01 PM
tonerockyhorror
Jun 29, 2007 07:38 PM
BAMbam160
Mar 2, 2007 07:48 AM
