08 CR W/out Radio
Old Apr 3, 2010 | 01:13 PM
s2kcrsrt8's Avatar
Default 08 CR W/out Radio
What do I all Need to install the radio, how do you get the radio door to open also is the wiring already there or do I need to run the wiring?
I have the Delete model, no AC or Radio
Old Apr 3, 2010 | 01:30 PM
psychoazn's Avatar
Delete models have no wiring for the features deleted.
In fact, CR's don't even have wiring for a softtop.
Unfortunately, I'm not sure what you need...
Old Apr 3, 2010 | 01:54 PM
geoff2005's Avatar
you probabl have to do a lot of custom work
Old Apr 3, 2010 | 04:43 PM
DFWs2k's Avatar
the quickest and cheapest route: boombox or mp3 player and headphones
otherwise you need to run the wiring/modify the dash/etc.
Old Apr 3, 2010 | 05:31 PM
Juice Steez's Avatar
You need the following for the door to work properly
10 77254-S2A-901 SPRING
11 77255-S2A-003 RUBBER, STOPPER
12 77256-S2A-003 LATCH
13 77257-S2A-003 CUSHION (MAYBE)
32 94305-30162 PIN, SPRING (3X16)
The whole Antenna assembly (Also Drill a hole for the Antenna in the rear right quarter panel)
6 39150-S2A-A01 ANTENNA ASSY., AUTO RADIO
7 39151-S2H-E01 ELEMENT, ANTENNA
8 39152-S2A-A01 BASE, ANTENNA
9 39153-S2A-003 PAD
10 39154-S2A-003 NUT
11 39156-S2A-003 INSULATOR
12 39159-S2A-013 FEEDER, ANTENNA
+Clips (15, 16, and 17) if you want to do it pro status OEM
as far as the radio... there's a few ways you can do it but I won't post because they maybe incorrect and I don't want to get yelled at again for posting incorrect info. (I'll just post what might help)
1 32100-S2A-A05 WIRE HARNESS, R. CABIN
2 32108-S2A-A10 WIRE HARNESS, RR.
3 32117-S2A-A10 WIRE HARNESS, INSTRUMENT
4 32120-S2A-A04 WIRE HARNESS, L. CABIN
5 32150-S2A-A10 WIRE HARNESS, DASHBOARD
6 32155-S2A-000 WIRE, INTERIOR LIGHT
7 32610-S2A-A00 CABLE, EPS GEAR BOX GROUND
8 32751-S2A-A03 WIRE HARNESS, DRIVER DOOR
9 32752-S2A-030 WIRE HARNESS, PASSENGER DOOR
10 90148-SE0-003 BOLT, GROUND (6X16) (WASHER 12.5MM) (ZN)
11 90149-SE0-003 BOLT, GROUND (6X16)
12 90153-SB6-003 BOLT, GROUND (6X12) (ZN)
13 95701-06012-08 BOLT, FLANGE (6X12)
GOD SPEED young s2kcrsrt8
Old Apr 5, 2010 | 04:18 PM
CapoArgentino's Avatar
Banned
Ah, my friend, luxury and comfort has finally beaten your inner racer
Oh well, it happens. Not all are born fit to drive pure sport cars w/ no AC or radio. I wish you good luck on your conversion
Old Apr 5, 2010 | 07:43 PM
s2kcrsrt8's Avatar
I am in no need of the radio its the GF who loves the music. I would rather hear a fine tuned machine
Old Apr 5, 2010 | 08:39 PM
operator207's Avatar
I know some people, if they really want a great system, will gut all the OEM wiring, and do a custom job. Looking at what all you might need from Honda, it may turn out to be cheaper to go that route (build your own harness). You would possibly still need the rubbers for the doors so the wiring is not just hanging out. Does the CR have auto windows? If so you could possibly use those rubbers to run the door wiring. If your not savvy enough to do this, there are plenty of stereo shops out there that could do it.
I did something like this in a barebones S-10. Had to run all the wiring ourself. It was not hard, if you have the time and patience.
Old Apr 6, 2010 | 07:55 AM
Banned
Oh I see. Well, I'd head out to the nearest Best Buy and grab a 80GB iPod for her and some F22C noise cancelling headphones
Old Apr 7, 2010 | 09:00 PM
s2kcrsrt8's Avatar
hahaha and yes it does have power windows ill just have to go around and get quotes to see what is cheaper i know they said its something like 2700 for AC/ Radio to be installed but im sure the majority is for the AC but I would rather have a shop do it so all the wires and everything are hidden. I just thinking off the top of my head but i remember when i bought it they said something like 800 for the radio unit installed but its probs a lot cheaper to go aftermarket and better sounding.
