08 Headlight Help
Old Nov 4, 2008 | 06:29 AM
Frunzman's Avatar
Default 08 Headlight Help
Ok so I just bought a 2001 championship type R white honda s2000. the front end was converted with 04 bumpers and it has 08 headlights and taillights. I was driving last night and i started to smell something burning so i pulled over, and sure enough whoever did the installation of the headlights bypassed the fuse box and ran it directly through the car (so i blew headlight fuses and my main battery fuse) anyway, my question to you guys is does anyone know if i can get a better wiring harness, possibly kyo wire harness, and if so, is it the H1 series? im having a hard time figuring out which harness i would need to make this work. plus now i also have to re-run wires from the headlight into the fuse box, and then into the car any help would be greatly appreciated
Old Nov 12, 2008 | 01:32 PM
s4play's Avatar
Without seeing pictures it's hard to give advice but sounds like previous owner did a crappy chop job on the install.
If done right, you can use your stock wiring and maybe using Bosch relays to take the main current of the power draw. I would go over the entire electrical system since he obviously did a lousy job. This is why I'm always scared at modded cars done by inexperienced people.
rk
stallone 81
Sep 17, 2012 07:31 PM
stallone 81
Aug 28, 2012 11:46 AM
AP1Driver
Aug 16, 2011 02:10 PM
Duo
Socal Swap Meet
Nov 1, 2010 07:33 PM
