2-1 USB on a Switch?
Old May 14, 2010 | 12:42 PM
Juice Steez's Avatar
Default 2-1 USB on a Switch?
So my HU has a single USB that I use for my iPod but I would like to wire it up to a switch (maybe a DPDT DPCO) so I can have another open port so I can use to switch to and from my thumb drive. Now this is a little above my paygrade and I'm stuck, I'm not sure how to wire this up. The USB uses 4 wires Red (PWR) Black (GRND) Green (Data+) White (Data-), but I don't know what switch I need or if I also need a diode.
I have a DPDT Switch that I picked up but not sure if it'ss work
3A 125VAC
1.5A 250VAC T85
Old May 14, 2010 | 01:28 PM
Unbeliever's Avatar
It's better to get a mini-hub. A switch isn't going to help you.
--Carlos V.
Old May 14, 2010 | 01:33 PM
DFWs2k's Avatar
^x2
Old May 14, 2010 | 01:52 PM
I've tried using mini hubs, they get the power needed but the HU does not recognize the devices attached. I have tried close to 10 different hubs (self powered only) and not one of them works.
Old May 14, 2010 | 03:06 PM
DFWs2k's Avatar
so instead of unplugging the device you are using and plugging in the other device, you want to be able to just flip a switch?
what headunit is it?
Old May 14, 2010 | 03:09 PM
Exactly, I want to mold one more USB and a switch on the passenger cubby for convenience and have the second USB plugged into my iPod and hidden behind the dash. My head unit is the JVC KD-AVX77, I do realize that I will have to power cycle the HU so that it takes the new USB device.
Old May 14, 2010 | 05:22 PM
DFWs2k's Avatar
i think you want something like this?
http://www.usbswitch.com/usb_2port_mini_switch.html
Old May 14, 2010 | 05:24 PM
DFWs2k's Avatar
i think the main thing you want to do when switching, is turn the power to the unused USB device off, let me try to draw a diagram of how i think it should go if you have to end up wiring it yourself with a switch
Old May 14, 2010 | 05:29 PM
I think I got it figured out, I'm working on the diagram now but I think I need a diode.
Old May 14, 2010 | 05:32 PM
DFWs2k's Avatar
can you use 2 dual on-on switches? trying to find a quad on-on switch
