2 amps - do i need to run two wires from the battery??
Old May 12, 2004 | 01:29 PM
Bass's Avatar
Default 2 amps - do i need to run two wires from the battery??
plan on using two amps - soundstream 414 to feed the frts & a pioneer to feed my spods
do i need to run two feeds from the battery??
Thanks
Bass
Old May 12, 2004 | 03:09 PM
s2qwik's Avatar
you would probably need to get a 1 into 2 fuse holder. it should look something like this:
hope that helps.
Old May 12, 2004 | 03:21 PM
jocko2's Avatar
You only need 1 wire from the battery (make sure it is large enough gauge), run it to a distribution block that will split it into two.
Old May 12, 2004 | 03:23 PM
Bass's Avatar
Thanks guys !!
Old May 12, 2004 | 07:49 PM
darkknight1999's Avatar
Steve run a 4 gauge wire to the area the amps will be mounted then used the above style fusable distribution block to split it into two 8 gauge leads that will run one to each amp.
See you saturday pal.
Old May 12, 2004 | 10:10 PM
NFRs2000NYC's Avatar
[QUOTE]Originally posted by darkknight1999
Old May 13, 2004 | 06:01 PM
Bass's Avatar
Thanks again Guys!!!
ok can either of you two WIZARDS please tell me what i need to order to finish my system?
the goal is to keep the factory head unit but run the speakers i have
1) i want to keep my factory head unit
2) I have s-pods with a set of Diamond ?? compentants
3) have a cheap ($100) set of canadce i used for the frt on my 01 figure i'll use these until i can save a few more pennies for some better frts
4) two amps - an older soundstream 414s that i'll use to feed the frt speakers and a pioneer amp (here's the link http://forums.s2ki.com/forums/showthread.p...6&highlight=amp ) to feed the S-pods
5) i have a bose rsx sub that's sitting in the basement as well
so i guess i'll need some #4 wire from the battery
then a splitter for the power
but what about a line ?? so that i can run rca's to the rear from the factory head unit
Thanks again Guys and John you KNOW i'll be looking for your help
Old May 13, 2004 | 06:39 PM
g-s2k's Avatar
[QUOTE]Originally posted by Bass
Old May 13, 2004 | 06:54 PM
Bass's Avatar
Thanks buddy - so i just need one of these??
can i pick one of these up locally for saturday? like does best buy carry them?
Old May 13, 2004 | 06:58 PM
g-s2k's Avatar
