I haven't seen one but if it is a soft blueish, white light, it may be a white LED. I have a white LED in my tag light, and it looks different than a regular incandescent light.
I'm curious what kind of socket is uses..
The parts dept wants $61.08 for the LED bulb!
Which either means it is specific fit that car's wiring, it is overpriced, or both!
I am guessing it would not be just plug an play with the S2000 anyway
I'm going to look on http://superbrightleds.com so compare similar lamps.... I am sure that is probably the way to go if you want the effect on your car too and don't want to drop a lot of cash to get it...
Just remove the OEM bulb and install the LED. Make sure the lights are on when inserting the LEDs, they will only light when installed right. If it doesnt light up when you put it in, turn it 180 degrees.
I can' figure out how to get the damn photos to work
