2006 oem alarm turn on randomly
Old Mar 20, 2018 | 05:36 AM
fullbritt's Avatar
Angry 2006 oem alarm turn on (screaming) randomly
Hi everybody,
I have a little problem with my factory alarm on my 2006.
Alarm screaming randomly... Sometime after 30 seconds after i closed lock my doors sometimes after 10 minutes...
Can i set sensibility on 2006 factory alarm ? If yes where ?
Any idea about my problem ? Can I unplug it ?
Thanks all, I am going crazy.
Old Mar 20, 2018 | 06:44 AM
windhund116's Avatar
AFAIK, the S2000 did not come with a Honda factory installed alarm. You must have a dealer or aftermarket one. They usual have sensitivity pot, somewhere. Need to find model/make, then Google or YT it.
Good luck!
Old Mar 20, 2018 | 07:28 AM
fullbritt's Avatar
In Europe, all models from 2004 have a factory alarm (uk from 1999 with an aditional remote).
If you read in owner manual (page 153 of french and german owner manual for example), functionality of factory alarm is explained.
Old Mar 20, 2018 | 08:24 AM
Then, you have the answer to your question. No?
Old Mar 20, 2018 | 09:13 AM
fullbritt's Avatar
Unfortunately, in user manual, it just explained how about use the alarm (lock the car with remote or with the key and how to lock the car without volumetric mode) but no information about fuse, module location, etc.
Perhaps that these information are in Workshop Manual but I have only 2006- version.
Old Mar 23, 2018 | 03:50 AM
lovegroova's Avatar
Based on UK experiences, this is most likely due to a low battery charge level.
Failing that, check the alarm sensor under the bonnet as that's the second most likely cause.
Old Mar 23, 2018 | 04:38 AM
fullbritt's Avatar
Thanks for your reply.
My battery is new (I was thinking about that at first so I have replaced with a brand new one)
Do you have a pic to help me to locate the sensor under the bonnet ? (or a link of Workshop Manual about 2006+ model)
Old Mar 23, 2018 | 12:09 PM
fullbritt's Avatar
I found the module and I unplug it. No siren, I can lock my S2k !!! I will try to try the problem now.
Old Mar 24, 2018 | 02:59 AM
fullbritt's Avatar
So, I unmount the module. His reference : 37110-S2A-E010-M1
It's the sounder made by Cobra for Honda. Now I search other parts of this system : sensor, computer, etc. If you have any idea.
Old Mar 24, 2018 | 05:19 AM
fullbritt's Avatar
My investigation continue ! Now I will try to locate other components.
