2008 Valentine 1 hardwire ground spot
Old Jun 22, 2008 | 09:38 AM
huberc's Avatar
Default 2008 Valentine 1 hardwire ground spot
Just picked up my 2008 s2000 and I'm installing my valentine 1 radar detector. All the guides on this site say to ground it on a nut with lots of other grounds right near the fuse box....but the 2008 doesn't have this nut...it's just not there. Seems like Honda did some rewiring up near the fuse box.
Has anyone found a good ground spot for their V1 (or equivalent)? I can't seem to find a good one at all. Very frustrating. The rest of the install was a breeze.
Old Jun 22, 2008 | 01:34 PM
R1_Pilot's Avatar
The nut with the grounds is there, its just difficult to see. Its waaay up by the ECU.
I just installed mine and used one of the two nuts that hold the hood release handle down onto the body. To use the one I am talking about you need to remove the kick panel though.
Joaquin
Old Jun 22, 2008 | 04:24 PM
roflitzjinno's Avatar
i would like to know this too but im doing it with an escort.. uh do you know how to take off the kick panel? is it just connected with clips?
Old Jun 22, 2008 | 04:30 PM
9kFever's Avatar
Just use an add a circuit.
Old Jun 22, 2008 | 04:31 PM
9kFever's Avatar
Mount it high.
Old Jun 22, 2008 | 04:43 PM
where would i get that? im so confused on how to do this with my escort. i dont know whether i should splice a wire or just try to connect it to the fuse box. but either way i dont know which wire would supply enough power or how to connect it to the fuse box.
Old Jun 22, 2008 | 05:44 PM
9kFever's Avatar
http://www.radardetector.net/forums/valent...structions.html
Old Jun 22, 2008 | 06:00 PM
thanks!
Old Jun 22, 2008 | 06:54 PM
huberc's Avatar
I managed to bolt it up, but what a pain. Earlier model years look much easier. Thanks Honda! :-P Oh well, I am loving the car.
Old Jun 23, 2008 | 05:39 AM
takeshi's Avatar
It's a pain on the 2006 as well.
