3rd Brake Light Mod - Wiring Help
I recently picked up the GS100A to modify the 3rd brake light to flash for greater visibility. After researching here I purchased the GS100A and Male / Female connectors from CorsoMotion (Set Male Female 2P 090M 090F GRAY Plugs, Honda taillights harness | 2x Male, 2x Female).
I have never installed connectors like this before. I assume I need to pin the red/black wires on the GS100A but I do not know where to get the pins nor do I correctly understand how to install the pin’d wires from the GS100A into the connectors. Any help, advice, videos would be great appreciated.
thanks!
thanks!
thanks!
thanks!
https://corsomotion.com/products/set...male-2x-female
Sumitomo HD Non-Sealed Connectors and Terminals
you can find nearly every connector for a honda here
Contact @Birdybog . He has a plug-n-play in 3d brake light strobe flasher. No need to reinvent the wheel.
-- Chuck
-- Chuck
I am very good with wiring, soldering, etc and love doing just about everything mechanical and electrical myself, but for the low price still just ordered the birdydog one for convenience.
For pinning, there are videos out there for just about every type of connector. Not hard to pin one.
First I've seen this.
Isn't the 3d brake light a LED which has hardly any resistance? Putting LEDs into many other locations on cars causes hyperflash as the system thinks the bulbs are burned out.
-- Chuck
-- Chuck
But in terms of the cruise control, the brake light switch (connected to the pedal) is the input used to disengage cruise control. . Simply needs to know if the pedal is pressed. That circuit does not need to care at all about the bulb or led, nor should it since if that were the case and the bulbs were out, cruise would not disengage when the brake is pressed. Plus, no reason to do any of that when you have a switch telling you when the brake pedal is depressed.
