5901 VIper install help!
Old Mar 14, 2009 | 12:45 PM
s2ki_control's Avatar
Default 5901 VIper install help!
hey everyone, I installed my viper 5901 alarm without the remote start and so far i have everything working except for the trunk release. I understand the trunk release wire from the viper harness outputs a negative voltage while the trunk release wire in the s2000 is looking for a positive voltage. I have searched the forums and found that I need a relay in order for this to work.So my question is,can anyone tell me how to wire up a relay so that I can output a positive pulse?Thanks to anyone who can help me .
Old Mar 14, 2009 | 05:26 PM
FoodeesJim's Avatar
Here's a link to an explanation on wiring up your relay.
Relay wiring
Old Mar 14, 2009 | 10:34 PM
thanks for helping , i got it working now
Old Mar 15, 2009 | 11:38 AM
DFWs2k's Avatar
did you have to buy a relay?
Old Mar 17, 2009 | 10:50 AM
snipe99's Avatar
he def needed a relay for a + pulse trunk...
Old Mar 18, 2009 | 03:28 PM
yeah i bought a relay i just didnt know how to wire it up to output it to a positive but now i do .. thanks!
Old Mar 23, 2009 | 12:00 AM
there is one more problem that im facing , the grounded whem armed ouput wire... i ordered a spdt relay for it to attach to the starter but from what i read from the12volt.com they dont recommend this because it "drains the battery withing 3 days" so where exactly should i wire this grounded when armed output if i dont use the relay? Thanks this should be my last question i promise
Old Mar 23, 2009 | 12:39 PM
snipe99's Avatar
what are you using the grounded when armed wire for? bypass?... this is either the blue/white wire or the blue wire in the auxiliary harness
Old Mar 23, 2009 | 10:32 PM
im trying to hook up some acessories like my tilt sensor and i need to tap into the GWA wire but that wire isnt hooked up yet .
Old Mar 25, 2009 | 12:44 PM
GrandMasterKhan's Avatar
before you do anything else give me a call and i can walk you through everything. The guide on 12 volt .com will not be as accurate as the information i can provide. I have done quite a few s2ks.
for example the starter wire listed on 12volt.com is totally wrong. and you will not need to use a relay for the starter wire at all or to bypass the clutch.
you have a pm
