After market electric horns
Old Sep 20, 2003 | 10:05 PM
simons2k's Avatar
Default After market electric horns
I'm looking into the Hella Twin Supertone Horns. They look kinda like oem but red. It does come with a relay but is it required? Couldn't you just replace the oem units and be done? I'm assuming the oem units have a relay connected to them already.
Old Sep 22, 2003 | 02:02 PM
Fusiondynamics's Avatar
From what I heard, some people just used the oem wire and changed out the fuse with a higher rated one. The problem with newer honda is that the horn now shares a fuse block with the brake lights. The correct way would be to have it installed with a relay and it's own fuse.
Old Sep 22, 2003 | 09:18 PM
fmah's Avatar
The Helms manual states that fuse #47 supplies the ABS modulator unit, Brake lights, Cruise control unit, ECM, High mount brake light, Horns(s) for all model years. The only stated difference between the models are: '00-01 models have a 10 A fuse and '02-03 models have a 15 A fuse (the later models have two horns instead of one). So, anyway, it seems that the only change is a larger fuse (by 5 amps) for the extra horn.
Wobbly
Jun 11, 2015 09:04 AM
ch33sey
Jan 10, 2008 10:24 AM
SSMugen
Mar 28, 2003 06:33 AM
00SType
Oct 21, 2002 05:12 AM
ace039
Jan 21, 2002 07:28 AM
