Alpine MRP-F450 amp overheats too quickly
Originally Posted by nrgizeman,Jun 18 2007, 03:48 PM
same issue here... but i live in san antonio, tx where temp avg 90F. but no prob at night time when its cool.
If you put some spacers between the board the amp is mounted to and the amp itself, it will allow additional airflow behind it and should cure any overheating problems, if indeed that is the issue.
Originally Posted by neoarroyo,Jun 18 2007, 07:36 PM
The amp is installed directly onto a carpeted board with the bottom of the amp literally on top of the carpeted material. I always thought this was iffy, as it seems to trap a lot of heat. Is this a normal mounting method or are spacers normally used? I'm going to run out and quickly check the grounding.
Originally Posted by Will,Jun 18 2007, 09:57 PM
from what i've seen, mounting the amp directly to mdf or carpeted mdf is normal, with some setups even installing trim around the amp to make it sit flush--further impeding it's heat-dissapating abilities. that being said, i'm just regurgitating advice someone else gave me on my setup. seems to be working so far. I have an Alpine mrv-f345 amp.
Originally Posted by sw05s2k,Jun 19 2007, 05:05 AM
Do you have the Bass EQ switched on? If so, try turning it off and turning down the gain on the sub a little. Also, turn down the crossover point on the sub to 150-180 or so.
The fronts don't have a x-over so set them above 65. Don't run the sub full range, no point, it isn't designed to do that. If it's still going into protection after lowering the gains, you'll want either a separate amp for the sub or a bigger/better 4 channel amp.
