Amp in center of spare tire.
Old Feb 15, 2006 | 08:16 PM
ptsmalls's Avatar
Banned
Default Amp in center of spare tire.
In my effort to maintain the spare tire and avoid placing the amp in the trunk I think i've seen an image of someone who put their amp in the center of the spare tire.
Anyone see this before ? Good/bad idea ?
I'm planning on running an Audiobahn aw100t and the best amp I can find that would fit in that center spot. (if possible.)
Thanks for the help.
Old Feb 16, 2006 | 04:48 AM
jwa4378's Avatar
I have only seen one installed in there once. I think it was an Alpine 220 (not sure on that...its was the small 50wx2). I doubt you will find a 400wrms amp that will fit in there. You can mount an amp over the gas tank, next to the spare. It just needs to be a thinner amp with good heat dissipation characteristics.
John
Old Feb 16, 2006 | 06:20 AM
NFRs2000NYC's Avatar
Running an amp thats not as good as you want, just for the sake of the spare tire isnt the best idea. Mount a better amp somewhere else....like to the left of the spare tire bolted to a board. Much more functional. Youll be there for 3 hours changing a flat with an amp and wiring tucked into the spare tire. Not the best idea if you ask me. Ditch the spare, and get AAA.
Old Feb 16, 2006 | 10:32 AM
ruexp67's Avatar
Besides, where are you planning to mount the Sub?
The well in the trunk is designed to carry your flat tire. If you have a sub in there, you are kinda screwed anyway.
Old Feb 16, 2006 | 03:57 PM
LATEOTT's Avatar
This is a great idea and many S2000 owners have done it. I have one 4-channel Alpine Amp in there, of which I'm using only two channels to power my rear speakers.
One S2000 owner has TWO amps inside his spare tire stacked with a homemade spacer to allow for air cooling.
It is possible to use quick-disconnects in case you need to use the spare.
Old Feb 17, 2006 | 10:47 AM
CosmosMpower's Avatar
I have a 2 channel amp powering my front speakers. Rear speakers were added afterwards and the amp wasn't changed to 4 by the previous owner. It sits inside the spare on top a towel to keep it from banging around.
Would you by chance be interested in trading your 4 channel for my 2 channel plus some cash? I'm planning on getting an aftermarket HU and changing to a 4 channel amp to power all 4 of the aftermarket speakers.
Old Feb 17, 2006 | 12:35 PM
s4play's Avatar
Good Point!
To be honest I never even thought of the fact that after I change my spare tire I will need a place to store the flat tire/rim!!!!
Cuz the only time I take the spare is on long road trips which means I most likely have a passenger and tons of luggage too...wow this could be a problem.
If I don't put the sub in the well for sake of having space in an emergency to hold the rim/tire, where else can I put a sub?
I remember someone here sells an enclosure for the sides of the trunk....?
rick
Old Feb 17, 2006 | 05:49 PM
ptsmalls's Avatar
Banned
rick...
the enclosure you're talking about is the one i ordered.
here's the pic of it installed: Sits in the passenger corner of the trunk...so if i did get a flat the well is still open to put the tire.
Old Feb 17, 2006 | 08:22 PM
lvietlboyl's Avatar
wrong thread
Old Feb 18, 2006 | 03:10 PM
99SH's Avatar
A couple of us have accomplished this with the Alpine 240 amp. Check out my recent post:
https://www.s2ki.com/forums/index.php?showt...7&hl=spare+tire
