Amp Recommendation
Hey everyone.. Im looking for a 4 channel amp to replace my old fried one. I had a Power Acoustik ps4-800 (800watt) amp before. I have one 10' Rockford Fosgate P310D4, here are the specs for it
Impedance: Dual 4 ohm
Power handling(RMS): 400 Watts
Power handling(Peak): 800 Watts
Motor Size: 77 oz double stacked
Coil Diameter: 2.5" Aluminum
Speaker Connector: 8 AWG Compression
Outer Diameter: 10.75"
Cutout Diameter: 9.22"
Depth: 5.9"
Tuning Frequency: 35 Hz
and MTX Thunder TXC6.1 6-1/2" Component Speakers, specs are
Sensitivity: 90 dB
Frequency Response: 44-20,000 Hz
Recommended RMS Power: 150W
Peak Power Handling: 300W
Impedance: 4 ohms
Glass Fiber Cone Material with Aluminum Deposition Provides Unmatched Musical Accuracy and Extended Low Frequency Response
25mm Teteron Dome Tweeter Provides Ultra-Wide Frequency Response to Blend Perfectly with Mid / Woofer
2-way Separate Crossover 18dB / Octave Engineered with Superior Components
5 Adjustable Tweeter Levels Provide the Best Linear Response Regardless of Tweeter Positioning and Placement
Large 1.5 Voice Coil
Up to 4.8 mm X-Max
3-Position Woofer Off-Axis Compensation (0
Depth: 5.9"
Sensitivity: 90 dB
Impedance: 4 ohms
Up to 4.8 mm X-Max
Originally Posted by Kermdaddy,Apr 3 2008, 10:10 AM
I have a slightly used Soundstream Van Gogh 320.4 I tried to sale on the forums a while back. If interested PM me back. Using a US amp now. A lot more expensive but a noticable improvement.
A good forum for info on the ultra high end car audio:
http://www.soundsolutionsaudio.com/forum/index.php?
Check out their shop too.
Sweet forum. Wasted half the day at work looking!
Try here,
www.elitecaraudio.com (used to be really good, lots of SQ heads, some with very expensive taste[i am guilty of this])
www.audiogroupforum.com/csforum/ (lots of world champions and audio pioneers)
www.diymobileaudio.com (how to build a "true" high end system without breaking the bank. Gobs of good information)
