Amp went into protection mode
I searched through this forum but didn't find the answers I needed.
I reset my ecu by unplugging the battery, and after i reconnected it, there is absolutely no sound coming from the speakers. The HU (alpine model) works fine, plays cd's and whatever, but there's no sound. I looked at the amp, and the protection light is on. I checked the fuse on the amp and the fuse in the engine bay connected to the power wire, and they're both fine. I checked the connection on the battery, the ground wire, and the remote wire, and they're all good. The amp is an Audiobahn AT4002T or something like that. Does anyone know what I can do? I've been driving around with no music for a few weeks now. Please help EJ's!
The protection light usually means there is an over-current condition (short on speaker wires or severely over-driven) or the amp is over-heated. I think we can rule out over-heating but perhaps the amp is finicky about the power-up sequence.
I'd suggest:
1. Remove +12v power from the amp, disconnect the turn-on lead, then re-connect power and see if the protection light is still on.
If it is then do:
2. Remove +12v power from the amp, disconnect speaker wires at the amp, then re-connect power and see if the protection light is still on.
I'd suggest:
If it is then do:
I'd suggest:
If it is then do:
I'd suggest:
If it is then do:
I was aiming more towards the overheating issue, but if it does it right off the bat it has to be something else. I would be hesitant to say its a current issue if his fuses are fine... Wouldnt one of them have blown (if they are appropriately sized) before the surge hits the amp? I guess it could work if it is downstream from the amp (speaker wires)...John
