Another pin question, please help
I have OEM HU and i just installed rear speakers just like ones
from Lucid's. Now I have a 4pin connector under the dash and couple positives & negatives from speakers that i just installed.
My question is:
Is that 4pin connector for 4 wires coming from two rear speakers?
If it is, where can I get the other part of 4pin connector that plugs into 4pin under the dash?
Please help?
My question is:
Please help?
If I understand your question right.....
You want to plug your newly installed rear speakers' wires to the pigtail for the available rear speakers on the '04?!
I doubt you can get the connector w/o getting the whole speaker kit from your dealer. In your situation I'd say clip the connector and just wire directly to the output wires. Might want to leave enough wire on the connector and keep it in case you ever wanted to return it to the car for some unknown reason.
Travis
Travis
I just installed a set of MarkS2002's S-Pods in my '04. After exhausting all of my resources, I clipped the 4 wire connector off, and crimped on a set of Bullet Connectors . This allows 4 connections (1 set per wire), so that in the event that they need to be unplugged, I can do so. Another option I considered, was an Interlocking 4 pin male and female connector. This didn't seem to be very sturdy though, so I decided against it.
The polatiry of the wires is:
Blue/Yellow (Driver Rear Speaker (+))
Gray/Red (Driver Rear Speaker (-))
Red/Yellow (Passenger Rear Speaker (+))
Brown/White (Passenger Rear Speaker (-))
Hope this helps
Hope this helps
evolution
Aug 19, 2007 09:10 AM
