Anyone tried this for an iPhone mount?
Old Jun 25, 2012 | 04:22 AM
JB Morrison's Avatar
Default Anyone tried this for an iPhone mount?
Hey All,
I'm a recent newbie to the forum with our recently acquired '05 S-2000. Wife gave me a Blitzsafe M-safe integration module to run through the OEM audio. I'm trying to figure out a discreet way to safely mount the iPhone, and found this: http://www.bracketron.com/products/u...-dock-pro-flex. Anyone tried one? Could use the USB outlet in it to power a GPS?
Thinking of installing a second 12VDC accessory outlet on the right side of the console to support the mount.
Thanks,
JBM
Old Jun 25, 2012 | 12:31 PM
CitadelBlue's Avatar
link doesn't load ....
Old Jun 25, 2012 | 05:04 PM
here's the link again:
Originally Posted by JB Morrison
Hey All,
Thanks,
JBM
Old Jun 25, 2012 | 10:55 PM
RussellJolly's Avatar
I just set my iphone on the open radio door, the hinges keep it from falling out...get a cheap silicone case and it will "stick" to the radio door. I wouldnt want my phone mounted to where i can mess with it anyways, just another distraction!
Old Jun 26, 2012 | 04:32 AM
takeshi's Avatar
If the GPS is powered via USB and uses less than 1.5A (per the specs in the link you posted).
It looks like the link in your first post has a period after the "flex". Remove it and all should be good. Also, try using the Insert Link button to help ensure that your URL is properly interpreted.
Not sure why you think is relevant. Obviously the OP needs/wants the device mounted for access. There are certainly people who use nav apps, ODB apps, Pandora, etc.
Old Jun 26, 2012 | 05:47 AM
I'm open for ideas, and like RusselJolly's suggestion. I think I'll snaking the iPhone cable under the audio head and see if placing the iPhone on the open radio door first to see if I'm comfortable with that arrangement first. Still looking at placing an accessory outlet on the right side of the console to power a GPS.
JBm
Old Jun 26, 2012 | 12:51 PM
cedarwood's Avatar
Check out Modifry... http://www.modifry.com/products/mounts/mdb_acc.htm and maybe this: http://www.quadlockcase.com/collections/products
RAM mounts are great and versatile, also. The X-Grip works really well.
Old Jun 27, 2012 | 04:28 AM
takeshi's Avatar
There are many mounts you can use with the Modifry or Panavise bracket (Modifry sells both). Both brackets are way to install and very secure but you'll need to purchase a device mount as well. I use ProClip but wasn't going to suggest it considering that the gooseneck mount in the OP was $35.
beneintray
Nov 4, 2014 11:43 AM
roho
Apr 23, 2013 02:23 AM
M.A.R.C.
Apr 27, 2012 05:46 AM
