ap1 cluster swap in a dc5
Old Aug 5, 2008 | 10:41 PM
dc5tunerx's Avatar
Default ap1 cluster swap in a dc5
hey, i plan on swapping in a ap1 cluster to my rsx. i found a cluster on ebay and wondering it its a good price for one if anyone can help me. also how much are the plugs from honda if anyone knows.
http://cgi.ebay.com/ebaymotors/Parts-Acces...6.c0.m245.l1318
Old Aug 8, 2008 | 09:52 AM
HiVolume's Avatar
I think it's a good price, but I prefer the ap2 cluster. I upgraded my ap1 cluster to an ap2 cluster a while back.
Old Aug 8, 2008 | 10:30 AM
jwa4378's Avatar
Some local guy swapped one into his EG civic, with ITR motor... Here is a quote from the thread (it contains what each wire is on the AP1 plugs, as well as his EG side)... I cannot link it, as you need to be a member to view the thread, not just to post into it... It also makes you wait 24 hours before you are a member from the time you sign up (prevents trolls).
AP1 Connector A (GREEN)----------------------------------EG Harness
A1 BLU/RED SEATBELT REMINDER-------------------------A1 BLU/WHT(SEATBELT LIGHT)
A4 SRS CONNECT TO A +12V POWER (A10 IGNTION POWER TO TURN LIGHT OFF) OR -------------------------------------------E5 BLUE
A7 GRN/RED LEFT TURN SIGNAL+----------------------B4 GRN/BLU LEFT TURN SIGNAL
A8 GRN/YEL RIGHT TURN SIGNAL+ -------------------------B3 GRN/YEL
A9 RED/WHT HIGH BEAM= ---------------------------A10 RED/GRN HIGHBEAM. IF POSTIVE TRIGGER HIGH BEAM CONNECT A10 TO GROUND,A9 TO SWITCH. IF TRIGGER TO GROUND. CONNECT A9 TO POWER AND A10 TO SWITCH BUT PROB SITUATION 1.
A10 RED/BLU HIGH BEAM(-) ----------------------------A5 BLK GROUND
A11 BLUE/BLK TRUNK INDICATOR--------------------------A2 GRN TRUNK OPEN
AP1 CONNECTOR B (GREY)-------------------------------EG HARNESS
B2 RED/YELL FUSE 45------------------------------B10 BLK/YEL POWER WIRE
B3 RED/BLK CIRCUIT 11-DASH AND CONSOLE LIGHTS +------------------------------------------------------------------------B11 RED/BLACK
B4 YEL FUSE 5------------------------------------------B10 BLK/YEL POWER WIRE
B5 WHT/RED FUSE 25---------------------------------B10 BLK/YEL PWR WIRE
B6 GRN DOOR PN INPUT GROUND SIG-------------------COULND FIND DOOR SWITCH JUST WRAP IT WIT ELECTRICAL TAPE.
B8 BLK GROUND----------------------------------A5 BLK GROUND
B9 BLK GROUND----------------------------------A5 BLK GROUND
B10 RED CIRCUIT 12 DASH AND CONSOLE LIGHTS (-) --------A5 BLK GROUND
AP1 CONNECTOR C (BLACK)---------------------------EG HARNESS
C1 WHT/BLK VSS OUTPUT-------------------USE TO CONNECT TO REG SPEEDO IF YA WANT. STEP DOWN FROM HIGH PULSE RATE TO REGULAR PULSE RATE.
C3 BLU/WHT VSS INPUT-------------------------CONNECT TO VSS CONVERTER
C5 BLU RPM SIGNAL INPUT------------------------B8 BLU RPM
C7 YEL/GRN COOLANT TEMP INPUT---------------------CONNECT TO ECT CONVERTER OR---------------------------------------A4 YEL/GRN
C8 YEL/BLK FUEL GAUGE SIGNAL INPUT(-)-----------------B1 YEL/WHT FUEL GUAGE
C15 BLU/YEL CRUISE CONTROL INDICATOR (-)-------------------D1 RED/BLU
AP1 CONNECTOR D (BLACK)----------------------EG HARNESS
D8 BLU/RED ABS INDICATOR INPUT CONNECT TO GROUND TO TURN LIGHT OFF OR CORRECT WIRE IF YOU HAVE IT.
D9 GRN/WHT E-BARKE INDICATOR-----------------------A9 GRN/RED BRAKE LIGHT
D11 WHT/BLU CHARGING SYSTEM INDICATOR(-)--------------------------------------------------------------------------------B5 WHT/BLU
D12 BLK/YEL FUSE 6-------------------------------------B10 BLK/YEL PWR WIRE
D13 YEL/RED ENGINE OIL PRESSURE SITCH INPUT (-)-----------------------------------------------------------------------B6 YEL/RED OIL PRESSURE
D14 GRN/ORN CHECK ENG LIGHT (-)----------------------A6 GRN/ORN CHECK ENGINE LIGHT
D16 WHT/RED FUSE 25--------------------------------B10 BLK YEL PWR WIRE
John
boostkrazy
Feb 18, 2013 10:54 AM
98integralsb18
May 14, 2012 11:41 AM
JAY_S2K
Apr 6, 2011 01:59 PM
CapoArgentino
Socal Swap Meet
Jan 13, 2011 02:36 PM
DaveOnLI
Jan 12, 2006 02:31 PM
