Wiring Clarification
I'm trying to install a new receiver along with the ASWC-1 on my 01 S2000, and am a little confused with the instructions provided as shown below in the images and would like some clarification please.
From the ASWC-1 Connections: 1) Connect the Black wire of ASWC-1 to Chassis ground; would this be the same as the Black wire from the Wiring Adaptor? 2) Connect the Red wire of the ASWC-1 to a switched 12 volt accessory wire; same as the Red wire from the Wiring Adaptor? The above seems straight forward; hoping that my assumption is correct. However, the below is the confusing part. 3) Connect the White/Green of the ASWC-1 and the wire in Pin 20 of the vehicle harness to Chassis Ground; In this case, isn't Pin 20 the Chassis Ground? If yes, then I would simply connect the White/Green to Chassis Ground similar to the Black wire of ASWC-1 from step 1) above? https://cimg1.ibsrv.net/gimg/www.s2k...a8d87c9540.jpg https://cimg0.ibsrv.net/gimg/www.s2k...d63adcb856.jpg |
Yes, You got that right on ground part! Is your mute function normally now? |
Originally Posted by 8.86.200
(Post 24465956)
Hey Oth, nothing to be sorry about, I read few post, some even dated back to 2011 by you, very good information, thank you for your continuous contribution on s2ki!!
So today, I pulled my head unit out, I had both yellow/green and Kenwood brown connected to pin14. which confused the system and only allow mute once, then I decide to try connect only Kenwood Brown wire to pin14 and viola!! Mute button worked like it should! Disregard the ASWC-1 manual do not connect yellow/green from ASWC-1 instead feed mute wire from headunit to pin14. Thanks everyone for the help, and hope this thread will help out those having issue with their mute button. Thank you, I can confirm this worked for me as well.. headunit mute wire to pin 14 KENWOOD KMM-BT225U |
