Axxess aswc-1 -- Revisit
Hey everyone. I know this topic has been beaten to death, but I am trying to get my mute button to work. I have the KDC-998X and it has a dedicated Mute (brown wire). I also read on the forum that we can tab the pin 14 (green/blue?) from the harness to a relay to reverse the polarity, which should work. I tried it with no luck. I am wiring the pin 14 to pin 86, grounding 30 and 85 and sending 87 to the Mute wire on the deck harness. Am I missing anything?
https://cimg5.ibsrv.net/gimg/www.s2k...2b090a731d.gif Thanks |
Your wiring looks correct (despite my originally misreading your schematic).
It's possible the mute circuit is blown - do you have +12v on the trigger (pin 14) when the mute button is on? Here are a couple maybe useful threads. https://www.s2ki.com/forums/uk-irela...roblem-868440/ https://www.s2ki.com/forums/s2000-el...t-work-879527/ HTH! |
OK -- Good news ---- Using the Axxess ASWC-1, you can work the mute button. What you need:
1) A deck that has a dedicated Mute/ATT. Ex, the Kenwood KDC-X998 has it. 2) Connect PIN 14 to the MUTE/ATT 3) Done -- Enjoy your mute. No relay need. |
I have same KDC-998X,I hook up the brown wire to pin 14, and it worked! now the problem is, once you press Mute button head unit initia ATT mode which lowers the volume, it will only cancel when I hit volume up button, same Mute button won’t cancel ATT mode. After cancel the ATT mode with volume up, pressing the Mute button don’t initiate ATT mode. like the mute button only function once. only way to get it work again is turn off the vehicle and cycle the ignition back on/acc does your mute button do this? Does it mean you have both brown wire from headunit and Green/Yellow wire connect to pin 14? thanks |
Not sure if this is what you're already doing, but according to this thread you need to hit the mute button twice each time to toggle on/off with the ASWC-1.
ATT/Mute come on when I press Mute button once, then headunit stay ATT/Mute, mute button has no response, ATT/Mute only cancels when I press vol+
Once I Mute the system once, the mute button went dead with no response, I can see the green indicator light on mute button comes on and off, but does nothing to the headunit. So if I followed the instructions correctly, i should have Brown wire from headunit and Green/Yellow wire from Aswc-1 both to the Pin14 right? |
ok, quick primer on mute functions...
There are two times of mutes: 1) "hardwired" where the headunit has a dedicated wire specifically to operate the mute. This is a legacy of built-in cell phones, where the phone would signal the headunit to mute. This is sometimes called "TEL/MUTE" 2) "software" where it's a command on the remote control just like volume up/down, and does not have it's own wire. Some headunits support one or the other, some none, and some both. The OEM headunit supports a hardwired mute, but it works backwards from most aftermarket headunits. The approach you may have seen using a relay converts the +12v signal from the mute button to a -12v (ground). I believe the ASWC-1 gets the +12v from the mute button on its yellow/green wire (attached to pin 14), but sends a "software" mute command to the headunit through the same connector as other commands. Thus the Kenwood's brown tel/mute wire should not be hooked up to anything as the ASWC-1 is not able to send a command this way, and the +12v the brown wire is sending is confusing it. When you disconnect it, make sure to leave no exposed copper wire to avoid shorts! |
Thank you for reply, I’ll try it out this weekend, the part I need to reassure is what color wire goes to pin14? Their manual says to connect Yellow/Green to pin14 white/green to pin20 You are suggesting white/green to pin14, then where do Yellow/Green wire go? thanks again for your knowledge, https://cimg4.ibsrv.net/gimg/www.s2k...4c0a4be644.png |
Sorry, my mistake, yellow/green should go to pin 14. I was trying to indicate that the Kenwood brown wire should not
also be hooked up, but I mistakenly switched the other wire's color when I typed from memory. I have corrected my above post. |
Originally Posted by oth
(Post 24464083)
also be hooked up, but I mistakenly switched the other wire's color when I typed from memory. I have corrected my above post. So today, I pulled my head unit out, I had both yellow/green and Kenwood brown connected to pin14. which confused the system and only allow mute once, then I decide to try connect only Kenwood Brown wire to pin14 and viola!! Mute button worked like it should! Disregard the ASWC-1 manual do not connect yellow/green from ASWC-1 instead feed mute wire from headunit to pin14. Thanks everyone for the help, and hope this thread will help out those having issue with their mute button. |
