Best Stock HU Setup/Solution
Old Feb 20, 2004 | 12:59 PM
redhurley's Avatar
Default Best Stock HU Setup/Solution
I know it is not ideal to use the stock head unit, but I was thinking of trying a set of Infinity Reference Components (which I can get for $120) and an amp before I was to go off and purchase a new headunit. What kind of amp should I use?
I was also wondering if I would be able to hook up an Infinity Basslink, because buddy of mine said he'd give me his for $100 and I figure it'd be worth a shot.
Could someone give me a better idea of the best possible setup I can achieve using the stock head unit?
Old Feb 20, 2004 | 04:24 PM
AndyS2's Avatar
Bass link for a 100 is a nice deal, but if you are not plannig to keep that HU for a long time, dont get the reference. Eventhough they are nice, as long as you amp them you dont ned to go low, spend the exta and get the perfects. I think you will be happier in the long run, especially after you get your aftermarket HU.
If you never plan to change the HU, get a small cheap 2 channel amp ( 200 watts is more than enough) and reference. For a small amount of money you will have great sound.
Old Feb 20, 2004 | 04:31 PM
redhurley's Avatar
cool, thanks for the info...with the stock HU, a 2 channel amp, and references...will i be able to hook up the basslink still?
Old Feb 20, 2004 | 05:49 PM
AndyS2's Avatar
Philll, aaa I dont know this heloooo
Daveee are you there?
I was trying to answer questions and I got stuck already
Old Feb 20, 2004 | 06:23 PM
ImportSport's Avatar
So how exactally do you run from the stock HU into an amp?
You run the powered lines into the amp, or does the stock HU have preouts?
Old Feb 20, 2004 | 07:16 PM
redhurley's Avatar
found a lil help from this thread:
http://forums.s2ki.com/forums/showthread.p...ad+unit+preouts
Old Feb 20, 2004 | 09:25 PM
dierk's Avatar
The stock HU does not have preouts. Either your amp must accept high level inputs or you must insert a high to low converter between the HU output and the amplifier input.
Old Feb 20, 2004 | 09:44 PM
dierk's Avatar
[QUOTE]Originally posted by redhurley
Old Feb 21, 2004 | 08:49 AM
NFRs2000NYC's Avatar
Doh, to late.....
Old Feb 21, 2004 | 11:03 AM
PJK3's Avatar
me too...
dierk is right... you'll need Lucid's rear speaker harness, and an amp w/ line level inputs. (i'd even suggest considering an outboard LOC (line output converter).)
you should be able to hook up an amp and Basslink to the OEM HU.
and before buying any speakers -- go listen to what you're buying... personally, i think that the Reference Series are a great bang for buck speaker, that will work quite well on an amp outputing in the 50Wrms x 2 range.
