boston pro60
Old May 20, 2006 | 06:26 PM
s2kv's Avatar
Default boston pro60
My tweets are really loud any way I can make'em lower like with the cross overs or something??
Old May 20, 2006 | 07:11 PM
hukares's Avatar
Bought my car with those speakers installed. They are horrible. The tweeters just hurt your ears unless you turn them down so low that you lose the sound you wanted in the first place. Put them on eBay and buy something else. I bought a used set of Focal K2's for what I was able to sell the used Bostons for.
Old May 20, 2006 | 10:32 PM
NFRs2000NYC's Avatar
Boston Pros suck???
No no my friend....you have a problem somewhere else....some of the best speakers Ive heard in my day.....
Check the amp settings.....
Old May 21, 2006 | 06:22 AM
Will's Avatar
I have the Boston SL60's, and there is a 3-position jumper on the crossover to adjust the volume of the tweeter itself.
Old May 21, 2006 | 09:52 AM
hukares's Avatar
Originally Posted by NFRs2000NYC,May 20 2006, 10:32 PM
Boston Pros suck???
I've done audio for for quite a while and I know that everything was set well. Balanced gain, crossover (none), etc. were all right. I just changed the speakers and the sound was great all other equipment the same. Plus the guy that owns the local shop told me that Boston is just "expensive crap". He's been a friend for quite some time and wasn't just trying to sell me new speakers. He's about 50 and has been competing since basically the beginning.
Old May 21, 2006 | 10:45 AM
MugenRioS2k1's Avatar
Boston
Old May 21, 2006 | 03:25 PM
s2kv's Avatar
So first thing I should check is the amp gain?
Old May 21, 2006 | 03:48 PM
hukares's Avatar
Are you using 2 amps for the components? If not, you have to use the jumper/dip switch inside (can't remember which, if any) to even them out.
I was only using 1 amp and could not reduce the harshness of tweeters.
Old May 21, 2006 | 05:54 PM
TwinC's Avatar
Nice to see some love for BA on S2ki. I'm a big fan, though they are relatively expensive... great SQ though.
The manual says you can attenuate the tweeters up to -4db. It looks like jumpers on the x-over, so if you don't want to do it the way described above.... just move the jumpers. If you want to do it right, follow the above directions. If you really don't want the hassle, just drop it to -2db and see if you like it... then to -4... then e-bay... or PM me. ;-)
Old May 21, 2006 | 09:29 PM
s2kv's Avatar
Thanks guys I will try the gains but wont be able to untill the weekend, I work all week. Thanks! Also when I turn on my radio the headrest speakers go on right away but the bostons lag a second, any way to fix that?? I have a stock head unit by the way.(I know, I know..... will get a new head unit when I have some more mula!) Is that normal?? My other cars it didnt happen like this? Thanks again for the help!
