Bought '02 H.U. - How Do I Set the Clock? (HELP NEEDED)
Old Jan 12, 2003 | 03:55 AM
cbender's Avatar
Default Bought '02 H.U. - How Do I Set the Clock? (HELP NEEDED)
Hi guys,
SpedXRacer was kind enough to unload his 2002 Head Unit on me -- and it works great -- but I recently disconnected the battery and now can't figure out how to reset the clock. My 2001 manual instructions don't work (as the controls are slightly different). Any suggestions? It's driving me nuts!
Thanks,
Old Jan 12, 2003 | 04:47 AM
KennyS2K's Avatar
If you look right under the butons, on the face plate, you will see in tiny fonts, "CLOCK" , "H" for hours, "M" for the minutes, and "R" for resetting the seconds. The clock buton is also the button for cd repeat and I recall the others as being 4-5-6- for the station presets. Hold the "clock" button in and press the other button(s) to get the desired results. This is from my foggy memory. If you need more info, post or pm me and I will go downstairs and find my owner's manual.
Old Jan 12, 2003 | 06:02 AM
SC_Highlander's Avatar
push and hold Scan, then press preset #4 to increment hours, #5 to increment minutes
Old Jan 12, 2003 | 07:11 PM
cbender's Avatar
Many thanks to both of you. I'll give it a shot in the AM.
Best,
CB
Old Jan 13, 2003 | 12:17 PM
cbender's Avatar
Got it, thanks. My garage isn't brightly enough for me to see the TINY letters, which is probably why I never figured it out. Thanks again.
s2kred
Apr 16, 2006 02:56 PM
tru
Aug 25, 2004 10:52 PM
SideShowB0b
Apr 9, 2004 02:04 PM
andys2k02
Oct 24, 2003 02:50 PM
Lotusman
Oct 11, 2002 12:31 AM
