Can someone tell me how to
I tryed looking around but cant find the answer to this. This will actually go in my daily beater, because I have an extra good battery, but I am trying to install a second battery, and still have it be part of the charing system. Is that possible?
ok whoa....first you have to ask yourself WHY you want to do this???
1) Intalling a 2nd battery only does one thing - increase your engine "OFF" listening time....
2) Once installed you will actually need to use a quality battery isolator otherwise you'll need a high output alternator as well.
3) So in essence you will be taxing and working your stock alternator twice as hard and it will need to be replaced sooner.
Most audio guys use banks of batteries for special cases but not for any type of a daily driver.
rick
rick
Hey Rick, how you been?
Well I wanna do it for off time, and because with alot of things running, my battery goes low even with the car on.
Thanks for the heads up, Im glad I didnt try to do it already
Humm.... really... I would say you need a new battery but I would have your alternator load tested too. Your profile says you have a 2005, and if thats the case I would bring the car back to the dealer for the load test(just call ahead to make sure they have a load tester and that their not just going to test for 12v when the car is off and the 14.4v when the car is on).
