cellphone mount
Old Aug 13, 2012 | 08:16 PM
Ashton23's Avatar
Default cellphone mount
Where can I get one of those cellphone mounts that mount next to the drivers right side vent?
Old Aug 13, 2012 | 09:29 PM
lltysonll's Avatar
modifry
Old Aug 14, 2012 | 05:04 AM
Ashton23's Avatar
Cool thanks!
Old Aug 14, 2012 | 06:51 AM
takeshi's Avatar
Just keep in mind that it's only the bracket. You'll need a mount that will bolt to the bracket but there are many options out there (don't overlook prior threads on the topic).
Old Aug 16, 2012 | 02:32 PM
Ashton23's Avatar
I'll search for some thanks
Old Aug 18, 2012 | 10:22 AM
CitadelBlue's Avatar
This IS something that can be made in one's garage.........
Here are the install instructions: Modifry's Dash Bracket Instructions
Old Aug 19, 2012 | 07:00 PM
Ashton23's Avatar
awesome thanks! anybody have any good holders they would recommend that will mount good the the mount itself? I have a htc evo phone, ill be getting a new phone here shortly but im sure it will be about the same size in general
Old Aug 19, 2012 | 07:07 PM
lltysonll's Avatar
http://www.proclipusa.com/devicehold...ceholders.aspx
Old Aug 20, 2012 | 06:25 AM
takeshi's Avatar
+1 for ProClip. They're not the cheapest but I've used them for years.
Old Aug 24, 2012 | 07:56 PM
AZS2KDancer's Avatar
If you don't want a permanent bracket mounted to your dash, I found one for only $15.00 that fits in the radio door when the door is down. It is a series of flat pieces that fit into that slot and there is no vibration from its use. I use a suction mount for a GPS or a phone.
That way, I can remove the entire set up and store it in the glove box, so it's out of sight when now in use, and not a temptation that something valuable might be an easy target.
I got it from an S owner on these boards who makes them. If you or anyone else is interested, I'll research his contact information.
