Cold Weather effecting sound
Old Jan 7, 2014 | 02:43 PM
Jeremy Clarkson's Avatar
Default Cold Weather effecting sound
Something weird happened on the way home today and I was wondering if it could be weather related. (as per my signature) I have a Pioneer head unit, a Sub, a JL amp, and focal speakers. Everything was installed less than a year ago, by me. I have never had any issues with the sound at all. When I started the car the morning the left speaker started poping, which has never happened before. The amp does not generate enough power to blow the speakers and the radio was not turned up too loud. I am in jersey and it is currently 12° F. None of the equipment has ever seen temperatures that low. I was wondering if the cold weather could cause any kind of issues that would make the sounds system operate improperly?
Old Jan 8, 2014 | 01:59 PM
Got in the car this evening temp is 28° speakers work fine....
Old Jan 9, 2014 | 06:13 AM
wadzii's Avatar
Banned
I have seen the surrounds on speakers rip or cause distortion when they are very cold and you turn em on loud right away. The rubber/foam gets stiff when its cold and the cone cant move like it wants.
Old Jan 9, 2014 | 06:54 AM
These speakers are less than 2 years old do you think the foam could tear that quickly? If it was ripped then wouldn't the sounds still be messed up once the weather warms up?
Old Jan 9, 2014 | 07:01 AM
wadzii's Avatar
Banned
It may not be ripped, it may just be stiff from being cold. Turn the radio on at a low volume for a while or let the car run w/the heat on before you head out just to get some heat in the surround.
Old Jan 9, 2014 | 08:41 AM
I thought they might be related so I let the car heat up for like 15min with a quick drive on the highway and the heat on blast. No change. It was weird at first it sounded like the tweeter on the driver’s side was having additional sound coming at of it almost like a way peddle in sync with the voices coming through the speaker, then I noticed that it sounded like nothing was coming out of the mids and the tweeter was distorted and even if I turned up the volume nothing really happened. My first thought was I blew a speaker or the amp.
I wonder if I should take it to the shop and have them check it out, the speakers are still under warranty.
Old Jan 9, 2014 | 12:03 PM
wadzii's Avatar
Banned
yeah if there was no change after it got warm then i'd say something is wrong/broken
Old Jan 9, 2014 | 02:05 PM
There is, they are fine now.
orella13
Jun 21, 2011 05:36 AM
RedSunS2K
May 3, 2011 03:14 PM
dammitjim
Oct 27, 2009 01:32 PM
su2ny
Jun 20, 2003 07:20 PM
revhi
Jun 15, 2003 08:31 AM
