Color of +12 constant power cable?
Old May 1, 2007 | 07:58 AM
buri73's Avatar
Default Color of +12 constant power cable?
Can you tell me which color wire is +12 constant power near the fuse box? From the picture on the bottom, would the cable be top, bottom, left, or right? I am looking to wire my homelink to constant power. Is the dome light constant power also?
Looking at the below picture, the arrow is pointing to +12 switched wire right? are the two plugs above it as well?
Old May 1, 2007 | 10:16 AM
nearwater4me's Avatar
Yes, the connector that the arrow is pointing is the switched 12V.
I'm not sure about the middle connector, but the one on the top is the power source that turns on w/ the parking light.
Dan
Old May 1, 2007 | 02:13 PM
modifry's Avatar
Honorary Member
Caution - Use an in-line fuse - both C and D come from the main ignition fuse under the hood (40 amps). You could fry a length of 18 gauge wire in about 2 seconds and never blow the 40 amp fuse.
Old May 1, 2007 | 02:20 PM
Hello, modifry
Could you elaborate on this?
How do I wire the fuse, and what do you mean by inline fuse?
Your help would be much appreciated.
Thanks
Dan
Old May 1, 2007 | 07:24 PM
buri73's Avatar
[QUOTE=modifry,May 1 2007, 05:13 PM] Caution - Use an in-line fuse - both C and D come from the main ignition fuse under the hood (40 amps).
Old Nov 7, 2013 | 07:37 AM
K LO QUE's Avatar
^ THANK YOU
fangtastic
Jun 27, 2014 06:13 PM
w00tw00t111
Apr 9, 2008 07:32 AM
K4RL
Nov 5, 2007 11:38 AM
Blurter
May 23, 2005 01:38 AM
CyrusA
Aug 13, 2004 08:23 PM
