Custom tool well sub box from ED?
not sure if this is a repost, but has anyone ordered a box from ED before? they say the box is 1cuft.
http://www.edesignaudio.com/index.php?cPath=1_78_113
it be totally worth it for $175,, ED confirmed the cutout is for a 12" sub, with 11" mounting hole. should be no problem for most of the 12" subs out there.
I don't have the box myself, but i can tell you that all of their products are top notch and well built via cnc and assembled by hand
They make very nice boxes and im sure tis is the same case.
You may want to check out this thread: http://www.icixsound.com/vb/showthread.php...highlight=s2000
The install was done at eD and they used their spec box. i dont know if this guy is on the forum or not
Sounds good...but I'm not sure about the interior size... The Ebay enclosure with MDF that sits that tall in the well has only .92cu ft interior. I'd see what you can find out about interior size before you buy it.
http://www.edesignaudio.com/product_info.p...products_id=584
it says 1 cu ft. that may not be enough for other drivers, but it works perfect with their 13kv.2, 13ov.2, e3.12, and e5.12.
basically any of their recent 12" drivers will work great in this box as they are all made to have sealed box sizes of 1.0-1.2 cu ft
