Dash MUTE to AMP?
Old Jan 23, 2015 | 05:54 AM
s2kCO's Avatar
Default Dash MUTE to AMP?
Hello guys, I'm running a new HU with AXXESS and the mute button is known not to work. However everything else works properly. I have new speakers set up to an amp. How can I run the remote wire from the amp to the mute button? Do I need relays of any sorts?
Thanks so much!
Old Jan 23, 2015 | 06:30 AM
oth's Avatar
oth
Here's a thread on using a relay to connect the dash mute button to the headunit's Tel/Mute input
if supprted by the headunit. It would be possible to do something similar with the amp, but would
work less well as you would be physically powering on and off the amp.
EDIT:
I should add that the concept is the same, but the wiring is not exactly the same - for the tel/mute
the relay is being used to ground a wire from the headunit, while for the amp the relay would be
used to cut the connection between the headunit's remote wire and the amp.
netanderthal
Oct 22, 2007 01:57 PM
cshamash
Mar 16, 2006 08:00 AM
S2000GT
Sep 23, 2005 09:45 AM
deanjones
Aug 11, 2005 03:55 PM
145
Jul 9, 2002 06:06 PM
