diamond or phoenix gold amp....
Old Sep 4, 2004 | 03:23 PM
s2addict's Avatar
Default diamond or phoenix gold amp....
which is a better brand to go with? Both about 100 x 4 max output power.
Also, while I'm at it....what size speakers are in the front of the s2k?
Thanks
Old Sep 4, 2004 | 10:58 PM
timg's Avatar
It depends on the levels. Low end PG and Diamond are VASTLY different from high end PG and Diamond. I love the high end Diamond that used to be Esoteric amps. The high end Ti Series PG is also VERY good.
Tim
Old Sep 5, 2004 | 07:11 AM
Kwando's Avatar
i've had/used my PG MS2125 for over 8 years now and i've never had a problem. I use it for my JL 12W6
Old Sep 5, 2004 | 12:10 PM
D-04's Avatar
At 100X4 I assume you are referring to the newer PG Xenon series. The TIs were great but only went up to 75X4. The reason I didn't go with the Xenon is that it has a similar power supply limiter to the JL amps. So if you bridge the channels you only get 200 watts. If you are just planning on running 2 or 4 speakers up front then it would work great, but it's not much power for a sub other then one of the 8"s.
The fronts are 6&1/2" BTW.
m1sterlaw
Oct 13, 2011 09:18 AM
yungjoc
Jun 29, 2007 08:17 PM
sandelkw
Mar 4, 2006 06:58 AM
kw2000
Jan 15, 2005 07:03 PM
flaco
Jun 15, 2001 12:59 PM
