Dimmer wire
Thing is that a dimmer and illumination wire are different. One is used to supply voltage to light up a unit another is to trigger the dimmer on the radio.
You must match them up. Please check the owners manual and the install harness into the car as to which wires to hook up.
Originally posted by LATEOTT
What current/voltage would a "dimmer wire" carry, and what exactly does it do to the lit up (or non-lit) radio? Is it a single voltage that triggers a "dim" mode on the radio? Is it variable?
Option Connector "E", labeled #9 in the Helm manual, (it is the top connector) is a good place to connect to. It is Hot with the Tailights. So anytime you turn the headlights/parking lights on your radio display will go dim.
The "illumination wire" is power for the display. It is typically connected to get power when the Ignition Switch is ON. Option Connector "C", labeled #6, (the bottom connector) is a good place to connect to. It is Hot with Ignition ON (and the starter not cranking).
Just leave it off its fine.
<-- yep that one) and post!
