directions on removing rear tray
Can someone tell me how I can remove the rear tray to stop my rattling? I'm reading posts about taking it apart from the cabin and trunk? which way? It doesn't even look like the pieces can come out.
And also, will I have any problems with an '02? (glass top)
you will NOT be able to get the tray over your roll bar. you must remove the spare and the lining in the trunk and pull it out through the trunk itself. Just remove all clips for the rear tray and then pull it out of the trunk. Once the spare is removed it will fall down slightly so you can pull it out that way
