DIY Shift Light
Old Oct 24, 2008 | 09:40 AM
Eric220's Avatar
Thumbs up DIY Shift Light
Just wondering if this is possible or if anyone has done it. The light on the dashboard used for the factory alarm usually just flashes red as part of the alarm. For those of us that don't have the factory alarm, the light is pretty pointless...has anyone managed to make a shift light out of this?
Old Oct 24, 2008 | 10:41 AM
GrandMasterKhan's Avatar
i'd like to know how to tap into that light as well. It would be great as a VTEC indicator or used as the flashing led for an aftermarket alarm
Old Oct 24, 2008 | 12:12 PM
hariku821's Avatar
mines not on the dash its close to the e brake.
Old Oct 24, 2008 | 12:16 PM
dparm's Avatar
That's because you have an AP1. The AP2 cluster has the LED right by the speedo.
You could just get one of those MSD RPM-activated switches. They have different "pills" for different RPM.
Old Oct 24, 2008 | 12:37 PM
Eric220's Avatar
Thanks I should have mentioned I'm looking to do this for an AP2 cluster since the light is in a convenient spot.
EDIT: Hopefully Modifry chimes into this thread.
Old Oct 24, 2008 | 09:05 PM
AP2 David's Avatar
in for update!
Old Oct 26, 2008 | 11:10 AM
CitadelBlue's Avatar
A couple of years ago, Cyclone36 (Joe) from Atlanta, GA made an electronic gizmo (The Blinking Light) that caused the alarm light to blink whenever the ignition key was in the off or removed position. It was a couple of wires and a circuit board that plugged-in the under the dash fuse box.... Perhaps you could PM Joe and then figure out how to use the alarm light as a shift light .....
Old Nov 30, 2008 | 12:37 PM
Eric220's Avatar
Bump, Modifry?
Old Feb 9, 2009 | 06:48 AM
Lane03's Avatar
bump
Old Feb 10, 2009 | 10:02 PM
aCab's Avatar
interested in this as well
