Door ajar beep is on when door is closed
Old Jan 29, 2010 | 07:52 PM
Driv300mph's Avatar
Default Door ajar beep is on when door is closed
Hi all -- I have a problem where I get the key-in-ignition door ajar beep when my door is closed.
Has anyone ever had this issue? Is there any special locations I should check besides the little rubber plunger on the side of the door jam? Not sure what would be causing the beep to go off when the door is closed.
Thanks
s2konroids
Jun 1, 2009 03:18 AM
