Electric Load protector. PLEAS HELP alternator doesn't charge
Old Jul 24, 2017 | 03:05 PM
kevinjames007's Avatar
Default Electric Load protector. PLEAS HELP alternator doesn't charge
Hello, I have a s2k year 2000. My alternator doesn't want to charge. The scanner said that is the "Electronic load protector" but I am not sure cause I can't find that only part anywhere. You guys know where I can find that part?
If it doesn't work what else can it be?
and if there's a specific relay that connect to the alternator ?
Old Jul 24, 2017 | 03:32 PM
Chuck S's Avatar
Have your battery load tested as these fail routinely while alternators rarely fail.
-- Chuck
Old Jul 24, 2017 | 04:36 PM
The battery does work cause the voltometro charge at 12.0 basically the car is running with the battery only. I already checked with advance auto parts if the new alternator that I put is working. And it is working. But doesn't want to charge. I feel so frustrated right now
Old Jul 24, 2017 | 05:49 PM
-- Chuck
i am going to check tomorrow every relay or things like calmly... cause I checked today and everything was good. But have a little doubt about the "Electric load detector"
Old Jul 24, 2017 | 10:51 PM
windhund116's Avatar
This link may help:
http://www.underhoodservice.com/hond...m-diagnostics/
Good luck!
Old Jul 25, 2017 | 02:51 AM
Chuck S's Avatar
12.0vDC is a dead battery. The car won't run on battery very long, the battery is just there to start the car not run it that's the alternator's job.
Alternator output should be constant in the 13.7vDC range, and into the 14s if the battery is depleted. A bad battery can still show 12.6v (full charge). Get it load tested before throwing more parts at it. 10 minutes at any car parts store most of which is standing around as the test takes only seconds once the hood/bonnet is open.
-- Chuck
Old Feb 19, 2018 | 04:40 PM
Sikocivic's Avatar
Check the ELD fuse. If I remember, its in the fuse box under the dash. I had this same problem on a road trip 500 miles from home. Replaced the alternator and still had no charge. Put a new ELD fuse in and everything works fine. Wasted $200 on an alternator that I did not need.
Bramblecat
Aug 19, 2018 01:49 AM
D10S
Mar 14, 2014 06:30 PM
chung
Apr 9, 2013 08:59 AM
ilscoobydooll
Jan 12, 2013 12:02 PM
atrain
Apr 30, 2006 08:34 PM
