Finding a 12v source that's only hot when the headlights are turned on
Old Jul 12, 2011 | 05:01 PM
cfreeman191's Avatar
Default Finding a 12v source that's only hot when the headlights are turned on
For the life of me I cannot find any instruction on this. I've looked all over the forum and googled, but I cannot find ONE place that tells me what wire in the dash or console would be good to run my autometer gauges off of. All I want is the gauge's lighting to be on when the headlights are on. Can anyone PLEASE help me! Sorry if this is a common thread but I've seriously been searching everywhere. Thanks.
Old Jul 12, 2011 | 05:57 PM
Boost-Me's Avatar
Would you be willing to have them on when your running lights are on or are you just looking for headlights only?
Old Jul 12, 2011 | 06:01 PM
Boost-Me's Avatar
****MAKE SURE YOU CHECK THESE WITH A METER BEFORE YOU TAP INTO THEM****
Headlights-Lo BLUE/RED (-) LIGHT SWITCH HARNESS (with your ignition wiring under the steering column)
Parking Lights RED/BLACK (+) AT KEYLESS ENTRY MODULE
Module 1 KEYLESS ENTRY IS LOCATECD BEHIND THE START BUTTON OF THE VEHICLE
Old Jul 12, 2011 | 06:50 PM
Awesome, thanks. Running lights are fine. Just wanted them to come on anytime i turn the switch. They're for my boost and oil pressure gauges, and judging from your username I'd assume you have around the same thing. What did you go with? and did you just use those piggy back side wire clips?
My link
Old Jul 12, 2011 | 06:56 PM
Boost-Me's Avatar
Yeah you can use those (t-taps are what most people call them), or you can strip back and splice in and tape up, either will be fine. Splicing in line just allows you to know a 100% that you have a good connection if you are having problems with things working.
Edited for grammer.
Old Jul 12, 2011 | 07:25 PM
oth's Avatar
oth
This thread will help you.
Old Jul 14, 2011 | 10:47 AM
Thanks a lot for the help guys. This should all be perfect. Now if only I could find a link to a T-Fitting for the gauge sending unit...hahah.
Old Jul 17, 2011 | 10:27 PM
Blindeye_03's Avatar
Are you planning to use a fuse? Why not just tap a fuse in the fuse box?
Old Jul 18, 2011 | 08:59 AM
2big4aS2000's Avatar
there are 3 unused power studs in the fuse box, one is constant, one switched and other i think is lights, use a fuse holder and female connector, it will push on and wire from there,
What T-fitting are you looking for, becareful all fittings are metric pipe thread....and most aftermarket sending units are normal pipe thread....
and you can not tap into factory oil pressure wire.
TakeshiS2K
Jan 28, 2013 08:17 PM
skinsfn36
Nov 29, 2012 07:51 AM
type-j
May 13, 2009 12:36 PM
HighwayStar
Mar 17, 2009 12:48 PM
wgp_hoppa
Sep 1, 2008 12:02 AM
