Focal Speakers?
Old Mar 1, 2011 | 12:56 AM
UHHSON's Avatar
Default Focal Speakers?
So i bought a pioneer headunit deh62000bt which fit and installded fine, but need the modifry thing to make the controls work, and i bought FOCAL 165A1 Component Speakers and they dont FIT! they go too deep? Has anyone tried these speakers? Help?
Old Mar 1, 2011 | 02:09 AM
JSWhaler's Avatar
You need to make an mdf spacer for them to work. Look to the ICE/ audio forum for directions.
Old Mar 1, 2011 | 10:38 PM
UHHSON's Avatar
Looked i cant seem to find one? I saw on ebay a kind of universal bracket 6 1/2 inch but not so sure
Old Mar 3, 2011 | 02:06 PM
Roughryder9969's Avatar
Go to a local car audio shop, they should be able to sell you one. I have focal 165 k2p and
it did fit with the spacer.
Old Mar 4, 2011 | 03:58 PM
ace123's Avatar
If you want to make one, it's pretty easy. You can, for instance, just get a jigsaw and a small sheet of 3/4" thick MDF from Lowe's. The MDF is just a few bucks. Trace the perimeters of the factory plastic thingie the speaker is bolted into and the inside speaker diameter with a sharpie. This will give you cutting outlines. It will be a roughly donut type shape. Cut it out with the jigsaw, then paint it or seal it if you want to. That's your spacer. Pre-drill holes for the mounting points, then screw it to the door, and screw the speaker into it.
Old Mar 4, 2011 | 04:15 PM
UHHSON's Avatar
Have you or anyone installed 165A1 before>?! anyone on this site have focal 165a1?
Old Mar 6, 2011 | 05:49 PM
S2Fine's Avatar
I will be installing the less expensive Polyglass 165VR in my S. How deep of a spacer did you use for your installation? I'll check the depth specs of the 166 k2p. I suppose I could pull my door panels and check, but I would prefer to get everything I need ready before hand. If the answer is already available why not . Thanks in advance.
Old Mar 7, 2011 | 03:25 AM
PAS2KNut's Avatar
Here is the how to make speaker spacers. Speaker Spacers DIY
Old Mar 7, 2011 | 06:28 AM
Dave-ROR's Avatar
Don't use MDF, or if you do make sure you seal them really well. Use a hard wood, or starboard.
Old Mar 7, 2011 | 10:15 AM
UHHSON's Avatar
What's a mdf? Can't I just buy speaker brackets
