getting headlights to always turn on
Old May 13, 2009 | 06:50 AM
type-j's Avatar
Default getting headlights to always turn on
Hi, for all you electronic guru's out there would i be able to connect a wire to jump the headlights to the ignition so when i turn the key on the headlights automatically turn on?
so i would connect a wire with two female pins to E and C. would that work?
Old May 13, 2009 | 09:29 AM
Stealth_SUX_'s Avatar
Make sure u fuse the link and also I thought that spade switch isn't for headlights its for ur parking lights..
Old May 13, 2009 | 11:02 AM
type-j's Avatar
do you know which one is for your headlights? and will jumping it to the ignition work?
Old May 13, 2009 | 12:32 PM
i believe headlight you will have to tap the wire.. I would use a fuse and relay to do it.. im not sure on the color of the wire for the headlights, maybe someone wit the schematic can chime in.
Old May 13, 2009 | 12:36 PM
correction i found it blu/red is the wire for headlights in the steering column, its for a 2000 s2000 but most likely the same in all years, just test the wire.
tone.101
Jul 4, 2012 08:41 AM
Matt15
Feb 19, 2011 07:44 PM
DuckieS2k
Inland Empire S2000 Owners
24
Jan 13, 2009 10:53 AM
dmw16
Jan 6, 2007 12:27 PM
soulcrew
Mar 29, 2005 05:48 AM
