headlight fogged up
Old Sep 25, 2006 | 02:55 PM
THAT K1D's Avatar
Default headlight fogged up
hey, im not sure exactly how it happened but in my front left headlight it gets condensation inside it an gets fogged up sometime.. doesnt effect driving.. but it looks bad.. how can i go about fixing this
Old Sep 26, 2006 | 07:01 AM
jwa4378's Avatar
you will need to re-seal the light housing. Go to www.ricks2k.com and check out the instructions for the installation of the headlight diffusers. You need to remove the bumper, remove the headlight anchors, then remove the headlights. Bake them in the oven at ~225* for 15-20 minutes each. Take a knife (or something flat) and SLOWLY pry the housing open. Get some sealant from your local car parts shop. Apply a HEALTHY bead of sealant along the seam where they connect. Rubber band them together and place back in oven. Take it out every few minutes to push the pieces more together as the sealant softens.
This would be a good time to clear your corner diffusers (if you are into that).
You can also just drill a tiny hold in the bottom of the housing to allow the moisture to move freely without condensing, but I have not seen the results of this yet.
I think this is also in the wrong forum.....S2000 Talk?
John
DISCONTD
Mar 26, 2012 11:39 PM
thewiseboatmaker
Apr 14, 2010 02:56 AM
mcola
Jun 7, 2005 07:22 PM
emrillive
Oct 25, 2002 12:17 AM
enguyen7292
Jan 22, 2002 04:29 PM
