Headunit install
Old Jul 21, 2014 | 08:58 PM
whatjones911's Avatar
Default Headunit install
I'm installing a Pioneer headunit myself and was wondering if people reused the oem headunit brackets or used the mounting sleeve that came with the pioneer?
Old Jul 21, 2014 | 09:04 PM
AP01's Avatar
I reused the OEM brackets, and they bolt up fine. but for us just use the brackets and its easier too
Sent from my XT910 using Tapatalk
Old Jul 21, 2014 | 10:59 PM
Ragnarok043's Avatar
the included sleeve are for cars that only has a single DIN hole with no mounting brackets, our cars are ISO mounted so use the OEM bracket.
Old Jul 22, 2014 | 07:52 AM
AZH's Avatar
AZH
I tried using the oem ones but broke 3 drill bits trying to remove the screws. For some reason they were too tight to remove. I ordered new ones from a honda dealership for like $10 and they arrived next day.
Old Jul 22, 2014 | 08:56 AM
Super Nintendo Chalmers's Avatar
Did you try to break them loose with a hand held screwdriver first? A lot of drills are high RPM-low torque so unless you had an impact drill you'd have a hard time removing stuck screws.
Old Jul 22, 2014 | 09:05 AM
Yeah the OEM brackets screws were on there really tight. Almost striped the head on one of them. Just make sure to get a good grip before loosening them.
The OEM brackets don't sit flush on the pioneer headunit because of the two protrusions on the bracket. I'm guessing that is okay? Also I might need washers as the unit sits too far in. Did anyone else run in to that problem?
Old Jul 22, 2014 | 09:25 AM
AZH's Avatar
AZH
Yes I tried by hand for a while before moving to the electric.
Btw you have the best screen name. Me fail English? That's unpossible.
Old Jul 22, 2014 | 09:27 AM
AZH's Avatar
AZH
I didn't have either issue (brackets not flush or sitting too far in). I have a kenwood 998 though.
Old Jul 22, 2014 | 08:18 PM
Thanks for the replies. I ended up using the brackets even though they don't sit flush. I made sure to tighten them up so the brackets don't pivot. The headunit didn't end up sitting too far in like I mentioned earlier.
The final product...
Old Jul 23, 2014 | 05:32 AM
Reckon's Avatar
Nice.
