Help with Flip up TV install??
Old Nov 14, 2002 | 11:04 AM
BigRedDog's Avatar
Default Help with Flip up TV install??
For those of you who have a TV installed custom on the dash, do you have any photos or tips on installing/cutting for the TV unit to fit in dash? Most likely i will have it professionally done but if it is possible, i would like to do it myself. Do you need any kit for mounting it or any wiring specs i need? Input would greatly be appreciated. Thanks.
Old Nov 14, 2002 | 06:22 PM
AOS2K's Avatar
Hey Big Red,
This is what I did for my S, it gives you two options.
https://www.s2ki.com/forums/showthread.php?...&threadid=90483
Old Nov 14, 2002 | 06:36 PM
AOS2K's Avatar
here are some pics for you to check out...
Old Nov 15, 2002 | 03:59 AM
1a-race's Avatar
Banned
mine is being changed to just a flat screen, no flip up any more for me. It is possible to put in yourself but measure 10 times cut once and repeat. The mount I made is fiberglass. heres how i did it.
1. apply masking tape to your whole dash. be sure to cover everything ie. seats, console, floor.
2. lay fiberglass on the working area
3. the messy part. use a paint roller to apply fiberglass resin
4. let dry, you now have a mold of your dash
5. cut the hole where you want the din in the fiberglass.
6. DONT FORGET TO DO THIS PART. lay your mold back on the dash and trace the hole you just cut onto the dash.
7. cut the fiberglass around the din. I left about an inch overhang.
8. paint it till satisfied.
9. start hacking away at the dash.
10. place the mount you made in the dash. secured mine with jb weld, works great, I found this out when trying to remove the mount for the new screen.
Hope this gives you somewhat of an idea.
Old Nov 17, 2002 | 07:26 PM
HKStallion's Avatar
How much is the rear view monitor? also where can i get it, looked all over and cant find a price. maybe a group buy? I want a display for info purposes, but don't want to cut the dash in possible.
Thanks
Chi-CityAp2
Jun 18, 2008 04:17 PM
Ws2006
29
Jun 15, 2006 06:16 PM
Ws2006
Jun 12, 2006 05:27 AM
hchu304
Aug 3, 2003 09:23 AM
silverbullet02
Nov 29, 2002 09:59 AM
