Help with front speaker install
Old May 23, 2005 | 05:17 AM
alks2k's Avatar
Default Help with front speaker install
Hey - I am looking for suggestions on how to best install my new front speakers. I have the MB Quart 6.5 componet set. The speakers are too deep to fit into the stock opening. If you have installed a 6.5 in the door did you use a spacer and if so do you need to do any "trimming" of the door panel to make them work? This set of speakers also has a cross over. Where is the best place to put this? If I keep it in the door what is the best way to secure it? Sorry for all the rookie questions but with past cars I have always had someone install for me but now I want to learn how to do it properly myself! If anyone has some pictures of their install I would appreciate it.
Thanks for the help!
AK
Old May 23, 2005 | 06:42 AM
Kronos's Avatar
Depends a lot on the speakers...I ran Eclipse 6.5" and used a 1/2 closed cell foam spacer. Had to trim a little on the door frame due to the basket. Mounted the crossover in the door...not my first choice but didn't want the hassle of having to pull multiple sets of wires through the grommett. PITA. Mounted with double sided tape and wedged it into place. No problems in over a year of use.
Old May 23, 2005 | 10:40 AM
darkknight1999's Avatar
Mount the cross-overs under the dash and run new wiring for them. Just use a 4 conductor wire to keep it simple.
Old May 23, 2005 | 10:43 AM
Oh and for the Quarts you'll either have to trim the crap out of the stock speaker basket or just make some replacement ones out of foam, plastic, or MDF. (if you make them out of MDF make sure you paint them to protect them from moisture.)
Old May 24, 2005 | 06:08 AM
alks2k's Avatar
Thanks for the help! It looks like I will need to get out the Dremel!
sakiv
Dec 8, 2011 05:50 PM
skhalid7
Apr 21, 2010 07:15 PM
sanjay
Apr 7, 2010 07:29 PM
Dragon_F6
Jun 12, 2004 09:17 AM
Ron H
May 16, 2003 09:40 PM
