Help: Gauge Cluster Stop working!
Old Jan 24, 2006 | 11:16 AM
Ben-G's Avatar
Default Help: Gauge Cluster Stop working!
I was changing clusters due to scratches. So i pulled out my original cluster and plugged in new one, it was working fine. The I wanted to keep the same milage so i swapped out circuit boards. Then i plugged it in and it lit up (30 secs) then just turned off, the other cluster did not even light up. I then decided to put back the circuit boards to their original housing, still not working!
The weird things is that everything on the cluster functions except the readings which require sensor readings. My signals works, key icon, battery, and Handbrake. My backlights for night driving still work. But no RPM, Speedo, Gas, Temp!
It's not the fuse, and there is power coming out of the harnesses, so don't know what it might be?
Your help is be greatly appreciated!
Old Jan 24, 2006 | 12:11 PM
xviper's Avatar
Originally Posted by Ben-G,Jan 24 2006, 02:16 PM
It's not the fuse
Are you sure? The gauge assembly is powered by 3 different fuses.
Old Jan 24, 2006 | 12:54 PM
Ben-G's Avatar
[QUOTE=xviper,Jan 24 2006, 04:11 PM] Are you sure?
Old Jan 24, 2006 | 01:34 PM
xviper's Avatar
They are all under the dash. They are #5, 23, 25.
Begin counting from left row, bottom (#1). When you get to the top (#13), come back to the bottom and continue with the right row (#14).
Old Jan 24, 2006 | 04:48 PM
darkknight1999's Avatar
Sounds like fuses to me as well.
Old Jan 24, 2006 | 05:34 PM
Ben-G's Avatar
I checked the fuses all good! I noticed that now the only light i get is battery indicator.
Any other ideas?
Old Jan 24, 2006 | 06:05 PM
Your gonna have to start testing to make sure your still getting the feeds from each circuit.
BTW those scratchs on the clear face of the cluster can be polished out. I've done it...
Old Jan 24, 2006 | 06:43 PM
Ben-G's Avatar
I tried scratch was very deep, too deep to buffout
How do i check the feeds?
Old Jan 24, 2006 | 06:58 PM
You need a digital multi-meter. Do not use a test light. You have to get a Helms and find out what goes to what. It won't be easy.
Old Jan 25, 2006 | 02:40 PM
dbzerk's Avatar
Have you jump started the car or done anything electronical to the car prior to this happening?
J2G Autosports
Oct 6, 2010 10:10 PM
MoogieBoogie
Nov 23, 2009 09:37 PM
cubide
Jul 6, 2007 12:29 PM
NSRsinfuLangeL
Apr 4, 2006 09:06 PM
S2K
May 5, 2003 08:48 AM
