Help! -- Need expert advice: Have I damaged my amp.
Originally posted by badboy3600
You do have the remote turn-on wire attached too, right?
I'm going to do more thorough testing in the morning (e.g, connecting the front speakers to the rear outputs, etc)
Hmm... sounds like it may have traveled up to the HU. Let me make sure I've got it right:
Before the 'incident'
HU LF ---> AMP LF = JOY
HU RF ---> AMP RF = JOY
HU LR ---> AMP LR = JOY
HU RR ---> AMP RR = JOY
After the incident:
HU LF ---> AMP LF = NO JOY
HU RF ---> AMP RF = NO JOY
After swapping:
HU LF ---> AMP LR = NO JOY
HU RF ---> AMP RF =
HU LR ---> AMP LF =
HU RR ---> AMP RR =
If the above are correct, it looks like there's no juice running from the HU's front channel.
Can you try an HU LR ---> AMP LF and see if you get anything? If you get signal, then I'd bet on fried front outputs at the HU. If you can test with another audio source cd walkman, etc you can eliminate the HU as a potential culprit.
I'm interested to know what turns out to be the problem, as I've done the same thing in the past, but lucked out and not killed anything.
After the incident:
After swapping:
HU RF ---> AMP RF =
HU LR ---> AMP LF =
HU RR ---> AMP RR =
OK, I switched both inputs from the HU to the amp this morning, A to rear channel, B to front. Now I get sound out of the front speakers but not the rear. I assume this means my HU is bad, not the amp, right? The front channel output of the HU is gone, right?
Oops, didn't know you were running rear speakers. I assumed the fronts were the only ones running on this amp.
So, one set of your RCA outputs is damaged. Does your amp allow all of the channels to run off a single input? If so, take the HU rear RCAs and run everything from that. Otherwise, the $5 fix is a set of RCA Y-cables to split the single RCA and run it into both the front and rear channels of the amp. You'll lose fader capability, but its cheaper than buying a new HU. Any warranties to take advantage of?
Just out of curiosity, was the head unit ON when you shorted the terminal to the case? I'm really surprised that this happened in this manner.
